Month of June 2021 (Nat'l Avg $3.045)
Discussion in 'The Daily Grind' started by Gord, Jun 1, 2021.
  1. EdwinTheMagnificent
    Today , 71 deg F in Northbrook , 69 in Elk Grove.
    17.2 miles , fcd = 76.3 x .943 = 71.9 MPG.
    Not so bad.
    Gord and BillLin like this.
  2. BillLin
    :D
    Gord and EdwinTheMagnificent like this.
  3. EdwinTheMagnificent
    From now until Sep 30 ( rainy season ) I need to make hay while the sun shines.
  4. EdwinTheMagnificent
    Today , in the Prius.
    67 deg F in Naperville , 66 in Elk Grove.
    35.1 miles , fcd = 66.8 x .943 = 62.99 MPG.
    Filled up Civic yesterday. 529.0 miles , fcd= 46.5 x 1.021 = 47.4 MPG.
    $3.359 /gallon.
  5. EdwinTheMagnificent
    Today , 70 deg F in Naperville , 68 in Elk Grove.
    35.1 miles , fcd = 68.6 x .943 = 64.7 MPG.
    I will be driving 150-200 miles this weekend , so I will be in the Civic.
  6. TheFordFamily
    TheFordFamily Well-Known Member
    Filled up the C-Max for the first time since March. I'll be filling up the Camry for the first real test of economy this Thursday when we're driving over 600 miles, mostly highway. We're attending a renewal of vows and reception for a family friend after COVID cancelled the event last year. Don't worry, we're both vaccinated due to work! The Camry is still sitting at just under half a tank and 55.6 indicated MPG over 520 ish miles.
    1265.3 Miles
    203 kWh used = 6.193 gallons equivalent
    6.193 + 12.285 = 18.478 gallons equivalent
    1265.3 / 18.478 = 68.48 MPGe
  7. Gord
    I have a whole vacation tank to report, I’m still catching up!
    Good luck with your trip TFF
  8. EdwinTheMagnificent
    Today in the Prius.
    59 deg F in Naperville and Elk Grove.
    35.1 miles , fcd = 65.1 x .943 = 61.4 MPG
  9. Gord
    Ok, here goes!
    6/6, went to holiday home for a few days:
    50.9 (FCD 53.2) / 102.5
    48.6 (FCD 50.7) / 105.8
    11/6 - father-in-law's funeral
    12/6, went to holiday home for the weekend:
    49.0 (FCD 51.2) / 103.0, 56°F
    50.7 (FCD 53.0) / 103.7 - fairly warm and sunny, 76°F, some A/C
    After unloading the car, popped to gas station as I had 5 miles of range left! After 0.3 miles it said I had Zero range:
    59.3 (FCD 61.9) / 2.0 - loads of slow speed engine off coasting.
    Tank Stats
    Miles on tank: 662.4
    GallsUS: 13.21
    Calc. MPG : 50.15mpg
    Calc. Range: 18.7 miles (allowing for extra in tank)
    FCD Range: 0
    FCD MPG : 52.38 MPG (4.44% over-report)
    UG MPG : 45.08 MPG (10.12% under-report) - unusually it was way off - the longer journeys with more 2-cylinder mode than normal skewed the numbers.
    No. of trips: 11
    Average trip length: 60.2
    Average speed 38mph
    Driving time on tank: 17hrs 22mins
    Days since last fill: 17
    Commuting: 2.2%
    Ave. Temperature: 64.9°F
    Gas station to home, 77°F:
    53.3 (FCD 56.2) / 1.9
    Back to work Monday, motorway route, 54°F:
    53.4 (FCD 56.2) / 21.5
    A lot more traffic going home last night 71°F:
    46.4 (FCD 48.9) / 19.8
    This morning, motorway route, 52°F:
    54.2 (FCD 57.1) / 21.7
  10. EdwinTheMagnificent
    Today , 55 deg F in Naperville and Elk Grove.
    35.1 miles , fcd = 64.5 x*.943 = 60.8 MPG.
  11. Die2self
    Had a fill-up last night before a quick trip to Cabot for fun night with my sister and her kids.
    Last fill-up was 5/11/2021 (35 days) so this was a quick tank for me. 3/4 of the tank was a run to Fort Smith and back in May.
    582.0 miles traveled
    - 56 miles to empty (when I left the garage it was showing 55, I love seeing the miles roll back as I drive :cool:)
    - 1 PIP left
    - 6/18 SOC
    - 14.07 hrs drive time
    10.178 gals pumped
    57.18 mpg (60 MPG displayed)
    only 2894 miles on the cars ODO from purchase last March with 315 miles on the ODO. :p
    keep up the good work gents.
  12. EdwinTheMagnificent
    I wish I could keep my ODO that low ! Instead , I have TWO cars I commute in so
    one car doesn't wear out so fast.
  13. Die2self
    working from home has it's pluses
    BillLin and Gord like this.
  14. Gord
    Definitely (both of you)!
    Last night, non-motorway route, temporary traffic lights are still there bit didn't bother detouring them as they've moved up the road a bit and aren't near another junction now, mostly crosswind SSW5, 72°F:
    47.2 (FCD 49.7) / 19.6
    To work this morning, motorway route, crosswind S6, 64°F:
    57.9 (FCD 60.9) / 21.3 - a record for the commute to work, first time the FCD has been over 60!
    That’s 61mpgUS :D
    Tank up 0.7 at 51.0 (FCD 53.7) / 105.8 / Range 625 . Guess gauge F««««|««««E . UG steady at 51.8 / DTE 594
    BillLin and Die2self like this.
  15. EdwinTheMagnificent
    Fantastic !
  16. TheFordFamily
    Filled up the Camry today! They're calling for severe weather, including hail, so I'm a bit apprehensive about the trip. But too late to back out now, or else we'll lose money on the hotel!
    539.1 miles
    55.6 MPG indicated
    10.029 gallons
    53.75 MPG actual
    3.32% offset
    Also curious is that it was around 1/3 full mark, and yet only has 3.2 gallons remaining in the tank. I wonder how much bigger than the claimed 13.2 gallons it actually is. Don't think Toyota would pull a GM and put a limiter on the tank, but not actually change the size a la Cruze.
  17. Gord
    Thanks Edwin :)
    Wednesday night, non-motorway route, fairly warm, mostly crosswind SSW9, 79°F:
    48.4 (FCD 50.9) / 19.8
    Thursday morning, motorway route, light rain, mostly crosswind NNW4, 64°F:
    51.2 (FCD 53.9) / 21.8
    Tank down 0.7 at 50.3 (FCD 53.0) / 147.4 / Range 580 . Guess gauge F««««|««««E . UG down 0.3 at 51.5 / DTE 549
  18. EdwinTheMagnificent
    In the Civic today , 72 deg F in Naperville , 73 in Elk Grove.
    36.8 miles ( railroad crossing detour ) , fcd = 49.3 x1.021 = 50.3 MPG.
  19. Gord
    Friday lunchtime, motorway route, started raining not long after I set off, 55°F, head/crosswind NE7:
    50.4 (FCD 53.1) / 21.4
    Didn't use my car over the weekend but managed 2 bike rides, Saturday 62.6 miles @ 18.7mph and Sunday 17.8 miles @ 18.4mph.
    I'm slowly getting faster after weeks off with an injury and other reasons.
    This morning, motorway route, 52°F, tail/crosswind NE5:
    53.4 (FCD 56.2) / 21.6
    Tank up 0.2 at 50.7 (FCD 53.4) / 231.9 / Range 495 . Guess gauge F_«««|««««E . UG down 0.1 at 51.4 / DTE 508
  20. BillLin
    Great bike runs, Gord. Glad you're getting stronger. The commute in the rain wasn't too bad either. :)
