Week of August 7 to August 14 (Nat’l Avg $2.347)
Discussion in 'The Daily Grind' started by Gord, Aug 7, 2017.
  1. Gord
    Welcome back to the grind :)
    The national average gas price is up 3.1¢ since last week to $2.347 - this time last year it was $2.123 so it's 10.6% (+22.4¢) more expensive.
    Diesel is up to $2.512 (+4.2¢). It's now 9.3% (+21.3¢) more expensive than this time last year. Diesel is at a 7% premium to regular.
    _______________
    No commute for me this week - still on vacation :D
  2. EdwinTheMagnificent
    Thanks for starting the thread, Gord. Today , 53.5 deg F , wind W2. 35.0 miles , 66.4 MPG. Tank is at 300.2 miles , 69.94 MPG. Taking Connie to see a movie tonight. Not sure if I want to see Atomic Blonde or Jab Harry Met Sejal. I'm sure I will see them both eventually. I hope I remember to shut the car off before I walk away this time.
    Gord, BillLin and PaleMelanesian like this.
  3. PaleMelanesian
    I think it's dead, Jim. The battery. After charging all night, it dropped to 11.0V several times this morning. No lights on, no wipers, no AC or anything. Three years old. And this is the upgraded oversized one.
    48.5 mpg / 4.3 mi to work this morning because of more idling.
    Tank is down to 50.2 / 451 mi.
    F____|_/___E
    Gord and BillLin like this.
  4. EdwinTheMagnificent
    What's up with Honda's charging system ? But you do make a lot of demands on the battery. Maybe Honda didn't anticipate/engineer for your driving style, Andrew.
    But maybe three years in a hot environment is all one can expect from a battery ? We don't have that problem here (heat) , and I have gotten six years of service from a battery in the past. But I was not doing engine-off glides, either.
  5. PaleMelanesian
    I've seen six or seven years in cars with "normal" drivers here. It's me. Well, me and Honda's "just enough" charging system. Those two together spell trouble.
    And that charger. I paid more for the smart one, only for it to be designed to be inferior. It's theoretically the better design, charge to a certain level and then hold it there. This specific one was just done wrong. The set charge level was too low, and then it just shut off instead of maintaining.
  6. Die2self
    Hmmmm. that's not good. Which did you buy? I have the B&D one. Which reminds me I should plug mine in as it just sitting there for weeks on end.
  7. puddleglum
    puddleglum Well-Known Member
    That's too bad Andrew. Is there any warranty on that battery that will ease the hit? Batteries don't seem to like extreme heat or cold, or not being fully charged.
  8. EdwinTheMagnificent
    Today , 59 deg F , wind = calm. 35.0 miles , 67.61 MPG. Tank is at 382.2 miles , 69.84 MPG.
    Gord, puddleglum and BillLin like this.
  9. PaleMelanesian
    Well, I have a new battery and all is well. One bonus to the upsized 51R battery, it's $20 cheaper than the tiny stock 151R.
    I have a theory. When I changed the size, I cut out part of the plastic battery tray/tub. The end I cut is the end that faces the engine. I should add/replace some heat shielding to keep the battery cool again.
    It was at the 36 month warranty this May. Juuuuust past. :rolleyes:
    39.7 mpg home with the old battery, engine on the whole time.
    61 mpg this morning with the new one.
    Tank is down a tick to 50.1 / 460 mi.
    F_____|__/__E
  10. Die2self
    had to make a run to the recycling yard to drop off some stuff and then to ACE hardware to look for some parts then home:
    62 / 7.4 miles (84F E@8) home to recycling then to ACE.
    home and push the car into garage backwards.:cool:
    43.6 / 3.4 miles (84F E@7)
    FCD = 49.0 (+0.1)
    tank:
    9.31 gals converted
    445.9 miles
    above 2/10 left in the tank (from 7/9)
  11. EdwinTheMagnificent
    Yesterday , went home early (10:00 AM ) as I wasn't feeling well. Scenic route , stopped at drugstore to get some medicine , left car in ready mode. 33.7 miles , 81.56 MPG. Today , typical highway inbound commute , 35.0 miles , 69.75 MPG. Tank holds at 451.0 miles , 70.58 MPG.
  12. BillLin
    Feeling better, I hope.
    Gord and PaleMelanesian like this.
  13. PaleMelanesian
    Had a meeting at 6pm so I got dinner in town.
    42.5 / 2.2 - pizza
    60.2 / 1.8 - meeting
    49.8 / 5.4 - home
    60.8 / 5.4 - this morning
    Tank is up a tick to 50.2 / 475.
    F____|__/__E
  14. EdwinTheMagnificent
    Today , 65 deg F , wind W4. 35.0 miles , 69.56 MPG. Tank is at 519.5 miles , 70.68 MPG. Scenic route tonight !
  15. PaleMelanesian
    Well. My tires were low. 40 in front, 35 in rear. I fixed that. 60/55 now.
    51.9 / 5.3 - home, 91F
    66.2 / 5.1 - work, 79F and humid. ugh.
    Tank is up a bit to 50.5 / 498 miles.
    F____|__/__E
  16. EdwinTheMagnificent
    Note to self : check Prius tires/
    Gord, PaleMelanesian and BillLin like this.
  17. puddleglum
    My cars been parked almost all week. Biked to work. Went out last night with my son to pick up a friend of his for supper and then again to take her home.
    50.1 - 5.3 miles for two trips.
    Put the car on the charger in between as my battery was down a bit from sitting. Probably should give it a full charge and maybe check my tires as well. Wow Andrew, I would never be brave enough to run my tires that high. I thought I was pushing the limits when I bumped mine to 50/44.
  18. EdwinTheMagnificent
    Today , 57.5 deg F , wind NW4. 34.9 miles (?) , 64.82 MPG ( frown). But yesterday's trip home helped the overall ( usually does) 33.8 miles , 79.7 MPG. Tank is now at 588.3 miles , 70.77 MPG. I am going to Rockford after work today , and filling up there. Somewhere right around 700 miles. I will take the scenic route there , but highway back. We have "killer raccoons" on the country roads at night . Deer , too.
    Gord, BillLin and puddleglum like this.
  19. puddleglum
    Quite a bit of running with the family this weekend. Saturday my son and I were out. Three stops over a couple of hours. 57.2 mpg - 9.1 miles total.
    Today started well. 58.5 - 6.9 miles to church and back. Brought it up to 60 after a round trip to a local park. Then a storm hit. Drove to some friends outside of town in a 30 mph crosswind and another car on my tail so no P&G. My daily avg. dropped to 50. :( Came home in the dark and rain so didn't make up much.
    Finished the day at 53 mpg - 24.8 miles.
    On the up side, I've been pleasantly surprised at how much I've been able use this car for our family runner as it is way cheaper to drive.
  20. EdwinTheMagnificent
    My Saturday driving was about 180 miles , about 45% 2-lane highway , 45% Interstate , 10% city driving. Approx 66 MPG. Could have been worse, I guess. Filled up Saturday night in Rockford at a Mobil station. Is that Top Tier ? 669.8 miles / 9.641 gallons = 69.47 MPG. I thought the pump shut off early , so I added another squirt. fcd = 75.6 , so multiply that by .93 , and maybe the more accurate # is 70.31 MPG. So , no GWR , or even PR. Just another 70 tank. Five in a row ?
