Re: FE Challenge - 2011 Qtr 1 If you know Andrew, he is coming after me for first place after his warm-up. Good luck everyone! GaryG
Re: FE Challenge - 2011 Qtr 1 That's the target. I'm not sure I can reach it, but it won't be for lack of effort.
Re: FE Challenge - 2011 Qtr 1 Gary, what is your current tank about ? Are you improving as much as Andrew is doing ? This morning my needle was always at F after 230km (140mi) while it was at 160-190km (100-120mi) during previous tanks... Of course with the more variable temperatures, the guessgauge is certainly playing with me... but what is great is when I left home the daylight was appearing, so after half the commute I switched off the lights Also the afternoon temperatures are really warmer and I have to hypermile as much as possible to prevent the engine fan to switch on may have to open the grill block soon... Denis.
Re: FE Challenge - 2011 Qtr 1 Denis, can you take a picture of your grill block? I am curious on how it looks like on your car.
Re: FE Challenge - 2011 Qtr 1 Scott, here is a picture when I installed my test Sunday : I may also simply remove the upper grill block instead of opening the lower one. For more information, see the thread here on Ecomodder. Denis.
Re: FE Challenge - 2011 Qtr 1 Hi Denis I can't say for sure what my tank will end up with but I can say my percentage will be going higher than it is right now. My first tank in this Challenge was what I now consider on the low side. Any time I get a chance to steal the new Explorer from my wife when she is not going back in forth to work, I do. That means I'm not driving the '09 FEH on the weekends and holidays at all. GaryG
Re: FE Challenge - 2011 Qtr 1 Filled up on the way home, 56.6MPG. No movement in division B but I'm now leading in the winter division.
Re: FE Challenge - 2011 Qtr 1 Ugh. Filled up last night; under 40 again. In slightly better news, I think I may be improving again. I was irritated enough at the poor tank to push harder today, and I think it may be working. -soD
Re: FE Challenge - 2011 Qtr 1 Threw down another weak tank. I like 3rd gear way too much. I promise to do better this time.... =)
Re: FE Challenge - 2011 Qtr 1 66.7 mpg 8.4 miles (highest segment) so far, looking forward for upcoming challenge -- :bananalama:
Re: FE Challenge - 2011 Qtr 1 This past week was my best thus far. 50.6 mpg on the tank. After refill I drove for a distance of 52 and got 60 mpg. I took a photograph to prove it. This tank is showing 54.1 mpg, but I'm nowhere near needing to refill as I usually do on Mondays. iHypermile Hypermiling is hipper-miling HIH-II
Re: FE Challenge - 2011 Qtr 1 Signups for the next challenge start in April, so be sure to look for the next thread for FE Challenge 13!
I'm about 2/3 of the way through my current tank... should be done in enough time to post it as my last tank for the challenge... sitting at 41.3 MPG right now, about 6 gallons left. I did stuff this tank and SG is calibrated to a 17 gallon tank to reflect it. 463 miles on the tank, DTE is reading 239 miles... can I squeeze it out in time for a new record?
I filled up. I had about 1/8 tank left. I'm not setting any distance record so there's no reason to push it to empty. 829 miles, 11.11 gallons = 74.617 mpg That's all for my challenge, so my final is: 2383 miles, 35.233 gallons = 67.635 mpg, 214.7% epa
Well done for such a cold winter Andrew. We had a colder than normal amount of freezing days than last year but still much better than your area. This dirty '09 FEH is cutting through the wind much better than last year also. My landscape took a worst beating this year so I've been using the new Explorer for hauling new plants. Those dirt roads really got it dirty last week and I was seeing an improvement in MPG till my son took it out racing around town. Washed the Explorer Saturday and seen my MPG drop right after. I haven't finished my final tank in the FE 12 Challenge but it's looking like a 62mpg tank with a final adjusted EPA at around 230% with a 61mpg average. Maybe I should post a picture of just how dirty my '09 FEH is so people here can see what I'm talking about. GaryG
*toss* the popcorn in air, opens my mouth and waits for that popcorn to come back down into my mouth... waiting for next challenge....
1100.7mi @ 70.153mpg With the biggest fill-up I wouldn't have reached 1800km (1118.7mi). I certainly not began my tank with a 100+mpg as I had to go inside the city this morning... I pumped up my tires to 3.8bar from 3.6 (55psi from 52) yesterday evening. The glides this morning with pumped up tires and full tank were looong when I didn't had to brake 3rd winter kilo tank in a row Am I an hypermiler ? Have fun, Denis.
