Cruise Control MPG
Discussion in 'Fuel Economy' started by Hypochondriac, Jun 24, 2017.
  1. Hypochondriac
    Hypochondriac Member
    Do you guys use cruise control? If so what kind of MPG do you get at around 55/60 MPH? I'm using the Torque app for MPG, and for my 2000 accord it's reading around 23 mpg. Which sucks.
    BillLin and xcel like this.
  2. alster
    alster Well-Known Member
    I use it a lot in both our 2016 Volt and 2010 Prius. The Volt on level ground at 55 mph varies from 50-52 mpg, that just on the gas engine. Now the Prius on level ground at 55 mph is 55-58 mpg. The Prius mpg's gauge is off from 2.5 to 3.5 mpg, if the gauge reads 55 mpg, the actual mpg's when calculated at the pump is anywhere from 51.5 to 52.5 mpg, this is consistent for nearly 160,000 miles so it not just a tank filling error. Most if not all Prius owners are well aware of this. The Volt is usually under reporting, the last fillup was 53 mpg when calculated it was 56 mpg, not bad for a Volt, just on gas 100%.
    Remember to check your dash mpg gauge most if not all are not accurate. I rather have it under report than over report the mpg's..
    BillLin, TheFordFamily and xcel like this.
    Hi Hypochondriac:
    You can calibrate the Torque app to actual by doing a top off to top off tank drive. Use a Garmin for miles because few take the actual miles vs. odometer/trip miles into account when the create their mpg calculation.
    Top off, reset your app, reset your Garmin, and away you go. When you are through with the tank, top off again, Total miles as indicate by the Garmin/gallons filled will be your actual. Compare that to the torque app and you will at least have an offset of sorts. Trusting an app is not as accurate as one would hope.
    kbergene and BillLin like this.
  4. Hypochondriac
    Thanks I'll try that.
    Whats wrong with using the odometer reading
  5. xcel
    Hi Hypochondriac:
    They are very inaccurate. From plus 0.25 to minus 3 percent for the hundreds of cars we have tested.
    IHTHs.
  6. 08EscapeHybrid
    08EscapeHybrid Moderator
    I use my cruise quite a bit as I use my car for work. On flat, level ground my Scangauge will read about 45 MPG when set at 55 MPH. 2008 Ford Escape Hybrid 4wd.
  7. EdwinTheMagnificent
    After two years of ownership , I STILL don't know how to turn on the CC in my Prius. I'm proud of that. There could come a time that I might need to drive 10-14 hours a day to get somewhere , and if that happens , I know I will have to use cruise at least part of the time (level roads only). For now , ignorance is bliss.
    xcel and BillLin like this.
  8. BillLin
    I can't tell if you're just being facetious. :) Since I doubt your car has RCC (but even then it is similar but with an extra button on the steering wheel controls for following distance), I suspect you have the standard stalk behind the steering wheel, around the 4 o'clock position. Button on the end of the stalk for on/off. Toggling the stalk down and up works as one would expect, but since it is you, better look at the inscribed labels. ;)
    Don't say I never helped you. :D
  9. EdwinTheMagnificent
    Thanks , Bill. My point is.......... I refuse to use the cruise.
  10. BillLin
    You're welcome, Edwin. I had my suspicions. :)
  11. phoebeisis
    Also-our 2006 Prius "mpg reading Thing"
    is -and always has been 3 mpg HIGH
    yeah-says 48 mpg 300 miles-actual using odometer and fill ups-is 44-45 mpg
    Slight aside-our Prius AC has been broken about 1 year
    consistent 2 mpg better no AC in NOLA suburb
    where AC used 9-10 months per year-
    BLACK prius-really gets hot
    the improved mpg despite open window
    but most driving-pure city- 25-40 mpg
  12. 08EscapeHybrid
    Does the a/c not working wreck havoc on the battery? The FEH has freon lines from the a/c system running to the battery pack to cool it. If your a/c breaks in an FEH, it can be nearly undriveable in the summer heat, because if the pack can't cool, the system limits the power.
  13. The Doctor
    The Doctor Old Dude, New Car
    It looks like this thread is growing a beard! BUMP
    Yes, I do sometimes use Cruise Control, when I'm on a nice flat road. On hills and curves, I can do better with P&G.
    [​IMG][​IMG]
    (I seem to be having a problem uploading a pic of my Scan Gauge II)
    I recently got 47mpg when under CC on a pretty flat county road at about 61 mph.
    Of course I have to work at it a little bit. My car wouldn't do that when she first came off the boat.
    :cool:
    puddleglum, BillLin and xcel like this.
  14. jcp123
    jcp123 Caliente!
    Cruise is great for flat roads. When there's elevation involved, it's not as good, though. I don't even have cruise in my car.
    I do use it almost always in the truck, though. When you're on the road 8ish hours per day, you don't want to be fiddling, plus it has terrain sensing which actually works reasonably well for FE.
    puddleglum and BillLin like this.
  15. litesong
    litesong litesong
    Agree. I also use it while on gentle rolling hills. I'll set it below the speed limit, while on the flats. Approaching a hill, I'll slowly accelerate. Ascending the hill, I'll let velocity slowly reduce, till on the hilltop the CC takes over again. Its like flattening out the hill, using CC & your ability to see the road contours ahead.
  16. EdwinTheMagnificent
    I have not yet used cruise in this car. In the Civic , I would use it on long trips on FLAT stretches , then shut it off to DWL
    when climbing a hill. Cruising at 65-70 MPH , then slowing to 55-60 climbing a hill , I was able to average 45 MPG.
    I thought that was pretty sweet at the time (2010).
  17. RedylC94
    The circa 1979 Sears (made by Dana ) aftermarket cruise control I installed myself in my '81 Mazda (after using it for a couple of years in my '72 Subaru) was much better behaved than the one of the Prius, sad to say.
  18. EdwinTheMagnificent
    I mostly just used the RF cruise control in my GLC.
  19. RedylC94
    "Mostly"?? What other kind?
    I find it harder to maintain a reasonably constant speed using only "RF cruise control" in the Prius as in prevous cars without staring at the speedometer, because the pitch and level of car noise doesn't correlate as closely with forward speed. That's a minor drawback of "e-CVT" (and mechanical CVT similarly).
  20. EdwinTheMagnificent
    In the GLC era , I thought I was brilliant for keeping within 55-57 MPH. Results were " okay"(46-49 MPG).
    DWL or P&G never occurred to me then.
    I do like the e-CVT but I also look forward to the next car , which will be a 6MT , I promise.
