Hi Jim: There are no mpg requirements. There is an octane recommendation that should be clearly listed in both the manual and around the gas cap. IHTHs and welcome to CleanMPG. Wayne
yeah, my manual calls for "87 octane or higher". IOW's, regular automotive grade fuel, which is 87, 89, 91-94 R+M/2 octane. so the question is, which octane is best for my motorcycle.
If your engine is stock, and you are not seeing exceptional operating circumstances (e.g., air temps), then 87 octane is generally best all-around for the health of the engine and your wallet. If you have higher compression, advanced ignition timing, higher boost, etc., then higher-octane than stock may be required. If you run your bike through Death Valley in the summer (i.e., very high air temps), you may need higher than 87 octane. If your bike pings during regular use, you either need higher octane fuel, or you need to find what is wrong with the engine and fix it. (Probably the latter.) If you personally feel better or safer running higher-octane fuel in your bike than is required, then that is likely the best fuel for you to run. -soD
