Just wondering if you could convert the Wh to kWh in the mileage logs? I ask this because I have gone over the readable limit. My Wh usage reads as 1.3317e+06Wh. A more readable format would be XXXXXX.X kWh. You only need to change it on the mileage logs screen. You can leave the add tank screen as Wh.
Hm. That seems a reasonable request Jay, but it will take a while to sort through. I'm sure it is stored as Wh and we'll want to change that. It's on the list now.
Its stored as Wh and it should stay stored as Wh unless thats whats causing the issue. If storing it as Wh is not a problem then all you have to do is keep it stored as Wh but display it as kWh.
