Which four functions do you set your ScanGauge to?
Discussion in 'ScanGauge' started by Chuck, Oct 4, 2008.
Which four functions do you set your ScanGage to?
  1. MPG
    77.6%
  2. MPH or KPH
    20.2%
  3. MAP
    3.8%
  4. GPH
    24.6%
  5. LOD
    29.0%
  6. LP
    2.7%
  7. RPM
    29.0%
  8. TPS
    38.3%
  9. fWT (Coolant Temperature)
    47.5%
  10. fIA (Intake Air Temperature)
    8.7%
  11. FPR
    0.5%
  12. VLT
    19.1%
  13. CPM
    1.6%
  14. IGN
    18.0%
  15. Custom Settings
    48.1%
  16. I use more than one ScanGage while driving
    3.3%
  17. I use metric settings
    13.7%
  18. SoC
    10.9%
Multiple votes are allowed.
  1. EdwinTheMagnificent
    Mpg Ave
    Fwt Lod
  2. aglie
    aglie Member
    I have a Fiesta and an UltraGauge. I have long-term MPG, short-term MPG, gph, and engine temp (because the Fiesta does not display this), engine load %, and gallons remaining in the tank. So I guess that is 6 things.
  3. 08EscapeHybrid
    08EscapeHybrid Moderator
    MPG, CHT, SOC, and LFT. I'm watching my LFT while in transition to E0 gasoline. Once that stabilizes, I think I will switch it to current trip average MPG.
  4. Kwon
    Kwon Member
    instant ...... trip average
    hp .......... mph
    the lower row is often changed to whatever else like rpm or engine temp, gph
  5. pickler
    pickler Well-Known Member
    LOD........DailyMPG
    S.Trim......AFR
    plus my car's factory instant MPG gauge. I sometimes switch to coolant temprature in winter time vs. Short term fuel trim. my fuel trims are always 0 but sometimes they really go negative in winter which means my car is running too rich, so i keep off the throttle to save gas, even though my AFR is reporting stoich (wrong because o2 sensor is still cold). I also use horsepower because my engine is most efficient when making 35 horsepower and the scangauge horsepower figure is very accurate in closed loop.
  6. joesgot4
    joesgot4 Well-Known Member
    Rpm
    Mpg average
    Mpg instant
    Mph
  7. RedylC94
    Currently:
    Battery current | Engine speed
    Fuel flow rate | Coolant temperature
    (Instantaneous MPG is trivial to compute from flow rate and speed)
    It's annoying to be forced to use up two of the four spaces for basic variables that are standard on normal cars.
    I switch to (12-V) battery voltage occasionally, and may add (traction) battery temperature in the summer.
  8. EdwinTheMagnificent
    With the Prius , I now only use Scangauge for RPM and more importantly , coolant temperature. I do compare the SG Trip info to Toyota's when I fill. The SG still under-reports by 1-2% , but that's still a lot closer than Toyota fcd.
  9. JonNC
    JonNC Driving Smarter Since 06/07/2011
    Not a Scangauge, but:
