2012 Toyota Prius PHEV-11 Spark Plug Changing
Discussion in 'Toyota Prius Family' started by xcel, Dec 16, 2019.
    The Prius PHEV has reached the 120k mile mark and it is time to replace plugs.
    This coming weekend should be fun. :)
  2. EdwinTheMagnificent
    This used to be incredibly easy in my 89 Civic. Probably haven't done it since 2000.
    With 98K on my Prius, I will be ( thinking about ) doing it soon.
    xcel and BillLin like this.
    Hi Edwin:
    Changing those plugs is indeed a real SOB as having to take off the wipers, wiper motor, and firewall/windscreen cowl, and engine cover plus all the associated bolts and clips just to get to the coil packs is a royal PITA!
    I am going to pickup a 4-pack set of Denso SK16R11 Iridium, NGK IFR5T11 Iridium, or Champion REA12WMPB4 possibly tonight in preps for the change. All arrive with preset gaps of between 1.0 and 1.1 mm but I will check the gap(s) at the Pep Boys before bringing them home for install this weekend.
    Not 30-seconds after posting this I started seeing Service, Repair, and Spark Plug Google ads on each new web site page I requested.
    Damn, why not just read my mind and get it over with! :D :D :D
    kbergene and BillLin like this.
  5. xcel
    The Toyota Dealership wanted $400 and there is no way they should be getting $400 for this job.
    10:45 AM start, 12:15 PM finish. Not including going to the local PepBoys for $22 worth of plugs and the small 9/16 spark plug socket. Damn is it a small one!
    The vid was pretty much dead on for all aspects other than it was easier to remove the HW than what he went through. On the reassembly, I had to remove the fastener nuts from the wiper motor assembly, readjust the left wiper and reattach as it was to high on the windshield. That was about the only hitch and rework.
    Wiper Motor and assembly removal.
    Plug installs.
    Engine cover goes on before the lower and upper cowl goes back in.
    The Desno's could have easily lasted another 60k miles.​
  6. EdwinTheMagnificent
    You make it look so easy. Only $22 for four plugs ? I thought they were made out of unobtainium or somethin' like it.
  7. xcel
    Hi Edwin:
    If there was one additional item I would suggest, change them on a warm day. It was nice here of course but I would not want to do this on a 40 to 50 degree day.
    The Iridium tipped plugs are sometimes expensive. I found a deal at Pep Boys. The Champions were a few bucks off each and I paid just over $5 a piece. Denso's were more than double and I could not find a reason why?
    In any case, I installed some new wiper blades along with the plugs and this project is complete.
  8. EdwinTheMagnificent
    Amen. My garage is not heated and if it's 40 deg , my fingers don't function. Thanks , Wayne.
