Infiniti's whacky new engine
Discussion in 'Nissan' started by brick, Aug 18, 2016.
  1. brick
    brick Answers to "that guy."
    I don't have time to format this properly as an article at the moment, but have you guys seen this?
    http://infinitinews.com/en-US/infin...ction-ready-variable-compression-ratio-engine
    Apparently Nissan has developed a variable compression ratio engine that works a little like variable valve lift, except it varies piston travel. They're claiming that it varies physical compression ratio between 8:1 and 14:1 to better control combustion in high-power and high-efficiency situations alike. I guess this will be replacing the current Mercedes-Benz sourced 2.0L in the Q50 and Q/QX30? It'll be interesting to see what it delivers in the real world.
  2. NeilBlanchard
    Wow, that is a bit wacky. It looks like it affects the cylinder / crankshaft centerline relationship? Honda has offset the cylinders away from typical TDC, to improve the efficiency.
  3. brick
    Someone kindly made a video clip showing what the linkage looks like in motion:
    Jay and BillLin like this.
  4. PaleMelanesian
    Surely that will be reliable for years and decades to come. :rolleyes:
  5. EdwinTheMagnificent
    Maybe even the whole warranty period.
    PaleMelanesian likes this.
