Hi All: It is 80+ degrees and humid as hell in Chicago tonight with T-Storm Warnings and Tornado Watches across the area. So what am I doing all afternoon and evening? Sourcing Extreme Cold Weather -60 to -100 degree F rated survival gear for a possible future project with an OEM to be named later. Wayne
Hi Tim: You would not believe the number of journalists that want to go on this one. Mike Sefton has already committed as well. This is going to be an adventure drive of a lifetime for sure. Now I just have to get the OEM(s) to follow through with their interest. It is a very cool vehicle(s) heading out on this one too. Wayne
Hi Jay: In case we need to drive the ALCAN, your name is on my short list. How do we get Tim out on one of these adventures is the real question? Wayne
Speaking as someone who works outside all day in any weather except lightning I recommend boots with (ideally multiple pairs of) removeable liners and multiple pairs of liner gloves. Being able to dry the liners overnight is a big deal. For me the top end stuff isn't worth the extra cost at the outer layer, but can be for the inner layer.
Hi Rich: Thanks. The boots I thought would best suit the needs of this drive have something like 8 layers including multiple liners. Here are the details. The Unique Baffin Inner Boot System Our multi-layer inner boot system creates a warm boot because body moisture is wicked away. A Hydromax II layer, similar to the material used in babies’ diapers, combined with a B-Tek four channel hollow fibre layer acts as a moisture control system keeping the foam dry and funneling water vapour out of the boot as opposed to felt packs used in other boots that compress over time and retain water. We’ve upgraded our innermost layer to an improved ‘Thermaplush’. It’s a chamois leather-like material that feels remarkably soft and smooth. A vaporized aluminum membrane has a silver surface which reflects energy back towards the foot. In our boots that are rated for very low temperatures, we use two of these. Baffin Impact Arctic Boot Specs RATING -100°C/-148°F BASE: Integrated Arctic Flex rubber base INSOLE: Rubber with Waffle insole and reflective “air bubble” underfoot OUTSOLE: Premium polar rubber LINER: Timberwolf leather and Diamond-Lite insulated nylon Wayne
Hi Mike: Only needed for stepping outside into the cold Polar air to take a leak more than likely. Wayne
Probably no need for -100F boots then. Something worth noting is that affordable materials that are flexible and waterproof at really low temperatures tend not to be durable at higher temps. I'm skeptical about the long term durability and effectiveness of a couple of layers of the boot you showed. I go with a less extreme temp rated boot with a greater emphasis on waterproofing and durability and adapt to varying temps by adjusting inserts and socks. The main downside of a less extreme boot is worrying about "synthetic rubber" cracking in temps below its specs. For example, Walmart's vinyl work boots won't work well at -30F. I've been happy with the Kamik's I bought last year.
Canada Goose makes some good stuff too. And some is made in Winnipeg http://www.canada-goose.com/expedit...-parkas&dwvar_4565M_Color=316&start=4#start=1 http://www.canada-goose.com/resolute-parka-8501M.html#start=1
Hi Rich: "If" it is minus 60 and something goes wrong, I am responsible for the safety and welfare of all that are along on the journey. I cannot consider what happens to survival gear in high temperatures a year or three from now. I need it to perform to spec for four to seven days in a row and only if something goes really wrong. After the drive is over, the participant’s $1,500 worth of gear can be tossed out and burned or used for the rest of their lives. I just have to make darn sure it works as advertised for the four to seven days of our drive in case it is needed. Mike, the exterior gear I am looking at goes beyond the Canadian Goose gear. Wayne
I think that's an honor best reserved for people with real hypermiling chops. Mine are a little rusty. OTOH I absolutely know my way around a gin and tonic if that helps. https://vimeo.com/107806971
How far beyond Canada Goose does this go? Canada Goose is pretty much the standard issue Antarctic parka, I figured there is probably a reason for that. It's pretty high quality stuff.
Catheter with a catch bag strapped to your leg would solve that problem. As this Walmart Shopper demonstrates.
Hi Mike: - 60 degrees F. I spoke with a Shell sponsored Iditarod musher about this last year. She said this gear is the real deal but may be to warm for most working situations no matter how cold it gets. Wayne
I was thinking along those lines... But I would only consider one particular type. Google "Texas Catheter" if you're interested.
