Yaris 2004 obd-II
Discussion in 'Toyota' started by wjacobusse, Mar 17, 2009.
  1. wjacobusse
    wjacobusse Member
    So where is this connector hiding?
  2. Damionk
    Damionk DWL Lover
    I did some quick searching and although I couldn't find anything that said where yours was exactly. I did find out that on some Toyotas about the same time frame had a black plastic cover over it. It would be about 1" x 3".
  3. msirach
    I drove a buddy's 08 sedan for a week and the obdII port was over beside the hood release. It was next to the dash plastic and the port was facing straight down.
  4. drummerboy2004
    drummerboy2004 Well-Known Member
    I am not sure there is a such thing as a 2004 Yaris, but Echo makes sense...
    In my 2008 Yaris LB, it is located under the steering wheel far to the left.
    Hope this helps you
  5. wjacobusse
    wjacobusse Member
    What's in a name. Here in Aruba they were always called Yaris.
    Thanks for the help.
  6. vtec-e
    vtec-e Celtic MPG Warrior
    Thats where it's hiding alright. Pull open the panel and in there, over the fuse board is the obd port.
    ollie
  7. drummerboy2004
    Not a problem, and remember you have one hell of a car regardless of model year:D
